UCCNC 1.2022 was released
Here is where you will find information about new versions and what is NEW about each update.
Postby cncdrive » Tue Sep 13, 2016 12:59 pm
After a long development cycle the UCCNC version 1.2022 was released today and is available for download on our website.
The direct download link: http://www.cncdrive.com/UCCNC/download_UCCNC.php
The changes and bug fixes to the prior version:
- G28.1 working was changed to support homing of any individual axis with the G28.1 code.
- If the software triggers a reset with external e-stop or limit switches the cause is written in the Status field on the screen.
- The THC related functions were totally reworked and optimised out.
- New THC anti-down function introduced.
- THC anti dive function was now added to all motion controllers, earlier it was supported by the UC400ETH only.
- Cahit's Autoleveler plugin was added to the installation.
- THC can be controlled also with hotkeys and Input triggers.
- New THC screenset and profile and shortcut icon installs with the software.
- exec.Question function to ask question and get answer from the operator.
- Bug fixed about loading new profile from the profiles tab page, the application did not always restart when different screenset has to be loaded.
- Bug fixed Encoder settings were not downloaded to the motion controller properly on software startup in some situations.
- Second probe input was added.
- Safe probe mode was added for probe protection.
- Axes now stops when the probe input activates to protect probe and to make probing possible with jogging.
- Probe routine was reworked and now the probe coordinates are saved to # variables. More info in the UCCNC manual.
- UC300ETH motion controller support was added.
- Bug fixed about the step-mode jogging, numeric values rounding issue was fixed.
- Operator lock/unlock function was added.
- Statistics window with total travel, M3, M4, M7, M8 counts etc. informations was added.
- Modbus plugin with Modbus TCP, RTU and ASCII communications with unlimited number of possible Connections and functions.
- Spindle pulleys function was added.
- Option to validate DROs with no need to press enter key was added.
- Step jog mode Shift override was added and bug about it's feedrate was corrected.
- M40/M41 digitizing function and Probe menu for digitizing was added.
- Bug about UC400ETH timeout and lost connection on first startup after updating firmware and had to be then restarted when connected via switches/routers and DHCP enabled was fixed.
- Port and Pin settings fields min. and max. values are now overriden from software when loading the screenset to make defining them in the screenset easier.
- #Events tag was introduced in the macro interface and the Drawings.dll was added to the macro class, so Forms can be built and events can be handled in the macros.
Return to UCCNC Change Log
