UCCNC 1.2026 was released
Here is where you will find information about new versions and what is NEW about each update.
Postby cncdrive » Wed Oct 12, 2016 12:52 pm
The changes and bug fixes to the prior version:
- On startup first time if MDI was entered with the Enter key it did not accept the typed in command, fixed.
- If the Toolpath view was in focus then the Enter key did not access the MDI, fixed.
- Softlimits issue after homing fixed.
- Screeneditor was missing the Add Codeview button, button was added.
- Adding new Toolpath view in screen editor had a bug and caused an exception, fixed.
- The M10/M11 commands had a problem when in some cases the commands were optimised out and accidentally removed in CV mode, fixed.
- The exec.Wait function was not precise, had a problem, fixed.
Return to UCCNC Change Log
