UCCNC 1.2024 was released
Here is where you will find information about new versions and what is NEW about each update.
Postby cncdrive » Thu Sep 29, 2016 1:21 pm
The changes and bug fixes to the prior version:
- Timeout parameter did not save in the Modbusmaster plugin, problem fixed.
- Autoleveler plugin jogdisable issue was fixed by the developer, plugin updated.
- Probe did not work in some cases, problem fixed.
- Softlimits parameters did not download always properly, problem fixed.
- Plugininterface Getbuttonstate missing function was added.
- A few (a minor number of on second etc. ports) pins were not assigned properly in the UC400ETH and UC300ETH motion controllers and did not work, problem fixed.
Return to UCCNC Change Log
