Simple MACRO Menu
Simple MACRO Menu
Postby Vmax549 » Tue Jan 16, 2018 8:38 pm
This is a Menu system for macros. It does use a txt file to drive the listing of macros. If you look at teh MacroMenu.txt file you will see teh structure to use to add more selections.
Name of your function , the name of the macro
Probe center of circle , M901
Probe Z top , M902
I set up the menu to load from a hotkey {alt , M} and assign teh Mcode (M20910) . That way it is always handy to use. Just press {alt,M} and it will pop up.
USe teh up / down keys to move up or down in the list . Then press enter or double click with mouse.
Unzip the ZIP file into your macro folder then assign a hotkey of your choice.
Now you can call up your special functions by NAME.
(;-) TP
MacroMenu.zip
(1.72 KiB) Downloaded 50 times
Vmax549
