first try to write a little macro
Postby CADdy » Sun Oct 08, 2017 2:56 am
Hi all,
my first post, my first problem :-)
I want to switch a waterpump on and off via a macro. It's no problem to do this manual with the following listing:
M20600.txt:
// Macro to switch waterpump off
 int Port;
 int Pin;
 Port = 1;
 Pin = 9;
exec.Setoutpin(Port,Pin);
exec.AddStatusmessage(" Waterpump turned OFF ");
M20601.txt:
// Macro to switch Waterpump on
int Port;
int Pin;
Port = 1;
Pin = 9;
exec.Clroutpin(Port,Pin);
exec.AddStatusmessage(" Waterpump turned ON ");
In 2017 screenset I've created a button to switch the relais on and off:
The macro M20610.txt contains the following:
bool buttonstate = AS3.Getbuttonstate(20610);
if (buttonstate)
   AS3.Setcheckboxstate(false, 20601);
   AS3.Switchbutton(false,20610);
else
   AS3.Setcheckboxstate(true, 20600);
   AS3.Switchbutton(true,20610);
Clicking on the new button toggles between on and off, shown with pictures "CheckBox_Btn_Up.png and CheckBox_Btn_Down.png". This function of the button ist what I want, but nothing happens. The relais is not switching. I don't know why. I assumed that the lines "AS3.Setcheckboxstate(false, 20601);" and "AS3.Setcheckboxstate(true, 20600);" be called alternately.
I think, it's a very simple error that I made. But I don't find it. It's my first try with UCCNC-macros. Please be lenient with my programming skills (and my poor english) ;-)
Best Regards
Peter
CADdy
Re: first try to write a little macro
Postby dezsoe » Sun Oct 08, 2017 9:52 am
Hi Peter,
Just change your M20610.txt to:
if (buttonstate)
   exec.Code("M20601"); // Turn off pump
else
   exec.Code("M20600"); // Turn on pump
while (exec.IsMoving()){} // Wait for exec.Code to finish
Postby ger21 » Sun Oct 08, 2017 10:54 am
Or, just use the M20610 for everything.
int Port=1;
int Pin=9;
if (buttonstate)
else
Postby CADdy » Sun Oct 08, 2017 4:16 pm
Hi dezsoe, Hi Gerry,
thank you for your professional help! Both solutions work perfectly.
I think the last line (while (exec.IsMoving....)) was my problem. I didn't know this line was necessary.
BTW, I changed the position of the button to a nicer place ;-)
Thank you very much!
Peter
CADdy
