axis movement until sensor is reached
Postby PowerCube » Mon May 27, 2024 12:32 pm
Hi everyone,
Does somebody have an elegant solution for the following:
I need a modified G31 that:
- if the state of the LED is true: moves the axis in the negative direction until the state of an LED changes from true to false
or
- if the state of the LED is false: moves the axis in the positive direction until the state of an LED changes from false to true.
PowerCube
Re: axis movement until sensor is reached
Postby Battwell » Thu Jun 20, 2024 10:17 am
the homing function would be the same as this?
explain what axis and its reason?
