Macro programmer
PostPosted: Mon Aug 28, 2023 11:58 pm
by Delco
Is there anyone on here that does upwork style work for creating or modifying macros for UCCNC.
I have a need to modify a existing ATC macro to add a rotary into it and also to modify a macro for my ATC turrent on my lathe that currently uses Mach3 but want to transition to UCCNC when the lathe update is finally released.
there seems to be a big hole in using uccnc in that if you are not a c++ programmer it is very hard to get uccnc to do what you want it to - I am sure there are lots of other users that have the same issues. I see the potential for a good programmer to make some pocket money and support the community at the same time.
Please send me a dm if you think you could help or reply here so other users could also use your services.
Re: Macro programmer
PostPosted: Wed Sep 06, 2023 3:00 am
by Delco
Still looking for a macro programmer ?
PostPosted: Sat Oct 28, 2023 11:53 pm
by Delco
So if we need to modify a macro where can we find help to do that ??? , or is it a case of if you cant program in C then forget trying to use UCCNC ?
I have tried to add a c axis into my M6 macro but failing.
Everywhere the comment " DC added C" I have tried to get it to do what I want but it errors ?
 * Macro: M6 Tool Change
 * UCCNC v1.2115 or higher required, with Messages plugin enabled
 * Unload current tool to load new tool
 * M6
 * Unloading Current Tool:
 *  If tool has "NoStore" tag in tool type field, will prompt for manually unloading tool
 *  If current tool has no slot assigned, it is assigned next empty slot (profileAutoAssignToolSlot=true)
 *  If no empty slots are available, will prompt for manually unloading tool
 * Loading New Tool:
 *  If new tool is not in a slot, will prompt for manually loading tool
 *  Loaded tool keeps assigned slot to be placed at on unload
 *  If ATC unload was detected to be unsuccessful, additional attempts will be made before failing
 * Tool Detection:
 *  Checks that tool was successfully ejected for both auto and manual tool unloading
 *  Checks that tool was successfully clamped for both auto and manual tool loading
 *  Checks that tool is clamped if new tool is same as current tool
 *  Sensor states are debounced with a given amount of time to meet their expected state before failing
 * atcLEDToolClamp=false and atcLEDToolRelease=false
 *  drawbar overtraveling above clamp sensor (no tool) or
 *  not reaching full extension to release sensor (jam/low air pressure)
 *  depending on 'atcOutputToolRelease' state
 * atcLEDToolClamp=true and atcLEDToolRelease=false
 *  drawbar petal clamped tool, travel stopped at clamp sensor
 * atcLEDToolClamp=false and atcLEDToolRelease=true
 *  drawbar petal unclamped, travel bottoming out at release sensor
 * NOTE: Tool table slot data is saved in custom profile section due to limitations in UCCNC API when auto-assign is enabled
 * Custom screenset fields can be used to represent tool table with macro to load and save changes (see M21050 and M21051)
// ### M6 CONFIG ###
// UCCNC has limitation in tool table API (http://forum.cncdrive.com/viewtopic.php?f=13&t=3537)
// if auto-assign is enabled, the UCCNC tool table can't be used to manage the tool slot number
// WARNING: DO NOT CHANGE AFTER A TOOL IS ASSIGNED A SLOT - STORED STATE OF TOOL SLOTS AND TOOL RACK WILL NOT MATCH
var profileAutoAssignToolSlot = false;
// we are resorting to using a custom section for tool slot in the profile to prevent losing data if auto assign is enabled
var profileToolTableSlotSection = profileAutoAssignToolSlot ? "M6ToolTable" : "Tooltablevalues";
// should restore to original the XY position after successful tool change
var restoreXYPosition = true;
// should apply G43 tool offset after successful tool change
var applyToolOffset = true;
// macro to use for tool offset probe
var toolOffsetProbeMacro = "M31";
// should ALWAYS run tool offset probe macro after a successful tool change
var toolOffsetProbeAfterToolChange = false;
// safe Z position for travel
double zSafe = 50D;
// Z position to release tool
double toolChangeReleaseZ = -55D;
// Z position to clamp tool
double toolChangeClampZ = toolChangeReleaseZ-25D;
// feedrate when moving to or out of tool release/clamp position
int toolChangeFeedRate = 200;
// distance above tool slot position to start tool change procedure with air purge and toolChangeFeedRate
double toolChangeOffsetZ = 50D;
// Whether to use toolChangeSlotOffset as side-[un]loading tool holder capture
// for side loading, change toolChangeSlotOffset:
//     (-1.0,0) for X side loading that starts offset from the tool slot by X-1.0 units
//     (0.-1.0) for Y side loading that starts offset from the tool slot by Y-1.0 units
var toolSlotIsSideLoad = false;
// tool slot position offset for inital move before going to actual slot position
// - can be used for side-[un]loading tool holder forks
// - can be used to help reduce chances of traveling over tool rack
// - ensure toolSlotIsSideLoad matches your setup!
var toolChangeSlotOffset = new Position(100D, 0D , 0D); // DC added C
// tool park position C
var toolParkC = new Position (0D ); //DC added tool park C
// tool slot XY positions
var toolSlots = new Position[]{
    // Slot 0 does not exist
    new Position(double.NaN, double.NaN, double.NaN), //DC added C
    // Slot 1
    new Position(100D,100D , 45D),
    // Slot 2
    new Position(100D,100D , 90D),
    // Slot 3
    new Position(100D,100D , 135D),
    // Slot 4-
    new Position(100D,100D , 180D),
    // Slot 5
// manual tool change position
var toolManualPosition = new Position(-130D, -80D);
// enable prompts to engage tool release and clamp
var toolManualATCPrompts = true;
// prompt before moving to toolManualPosition
var toolManualPromptBeforeMove = false;
// enable prompt for tool offset probe after manaul tool change
var toolManualToolOffsetProbePrompt = true;
// OUTPUT to engage tool release
var atcOutputToolRelease = new PortPin(1, 17);
// OUTPUT to engage tool clamp - optional, if null it expects atcOutputToolRelease off will cause tool clamp
PortPin? atcOutputToolClamp = null; // new PortPin(3, 2);
// OUTPUT to engage air purge
var atcOutputPurge = new PortPin(1, 16);
// delay in milliseconds before turning atcOutputToolClamp off - 0 = do not turn off
var atcToolClampOffDelayMS = 1000;
// delay in milliseconds before turning atcOutputPurge off - 0 = do not turn off
var atcPurgeOffDelayMS = 1500;
// INPUT to detect if a tool is clamped
var atcLEDToolClamp = 95; // InputPT3PN11
// INPUT to detect tool release
var atcLEDToolRelease = 96; // InputPT3PN12
// Interrupt from failure: 130=Cycle Stop or 512=RESET
var buttonInterrupt = 130;
// Cancel from user: 130=Cycle Stop or 512=RESET
var buttonCancel = 130;
// ### M6 MACRO ###
 // check if machine is homed/referenced
if(!exec.GetLED(56)||!exec.GetLED(57)||!exec.GetLED(58))
    exec.Callbutton(buttonInterrupt);
    Prompt("M6: Tool Change Failed", "Machine is not homed", "OK", PromptStatus.Error);
    return;
while(exec.IsMoving()){};
// store original XY position and modal to restore
var originalPosition = new Position(exec.GetXmachpos(), exec.GetYmachpos());
var originalModal = AS3.Getfield(877).Split('|');
var toolCurrentNumber = exec.Getcurrenttool();
var toolNewNumber = exec.Getnewtool();
// Check if there is a tool in the spindle
if(toolCurrentNumber > 0 && !AssertClampPosition(atcLEDToolClamp, true, atcLEDToolRelease, false)){
    Prompt("M6: Tool Change Failed", "Tool not in spindle", "OK", PromptStatus.Error);
    return;
// if same tool, do nothing
if(toolCurrentNumber == toolNewNumber){
    return;
if(!ExecuteGCode(
    // stop coolant and spindle
    "M9", "M5",
    // move to safe z
    "G90 G00 G53 Z" + zSafe,
    // cancel out tool offset, scale and rotation
    "G49 G50 G69"
    exec.AddStatusmessage("M6: tool change interrupted");
    return;
// read the tool slot #
var toolCurrentSlot = toolCurrentNumber > 0 ? int.Parse(exec.Readkey(profileToolTableSlotSection, "Slot"+toolCurrentNumber, "0")) : 0;
var toolNewSlot = toolNewNumber > 0 ? int.Parse(exec.Readkey(profileToolTableSlotSection, "Slot"+toolNewNumber, "0")) : 0;
// read the tool desc
var toolCurrentDesc = exec.Readkey("Tooltablevalues", "Description"+toolCurrentNumber, "");
var toolNewDesc = exec.Readkey("Tooltablevalues", "Description"+toolNewNumber, "");
// does the new tool require a manual tool change
var toolNewIsManual = (toolNewNumber > 0 && toolNewSlot < 1);
// check that tool slot not out of range
if(toolCurrentSlot >= toolSlots.Length){
    Prompt("M6: Tool Change Failed", "T" + toolCurrentNumber + " slot #" + toolCurrentSlot + " out of range", "OK", PromptStatus.Error);
    return;
if(toolNewSlot >= toolSlots.Length){
    Prompt("M6: Tool Change Failed", "T" + toolNewNumber + " slot #" + toolNewSlot + " out of range", "OK", PromptStatus.Error);
    return;
// read and parse tool flags
var toolCurrentTypeFlags = exec.Readkey("Tooltablevalues", "Type"+toolCurrentNumber, "").Split(new char[]{' ', ',', ';'});
var toolCurrentStorable = !Array.Exists(toolCurrentTypeFlags, f => string.Equals(f, "NoStore", StringComparison.InvariantCultureIgnoreCase));
// create function for manual tool changes
QTCDelegate ExecuteManualToolChange = (string status, ToolChangeAction action, int toolNumber, string toolDesc, bool skipClamp) => {
    exec.AddStatusmessage("M6: " + status);
    var result = DialogResult.None;
    var distanceX = Math.Abs(exec.GetXmachpos() - toolManualPosition.X);
    var distanceY = Math.Abs(exec.GetYmachpos() - toolManualPosition.Y);
    // check if not at manual tool position
    if(distanceX > 0.0001D || distanceY > 0.0001D){
        result = toolManualPromptBeforeMove ?
                    Prompt("M6: Manual Tool Change", "Move to position for manual " + action.ToString().ToLower() + " of T" + toolNumber + "?\n" + toolDesc, "YesNoCancel", PromptStatus.Warning) :
                    DialogResult.Yes;
        if(result == DialogResult.Yes){
            if(!ExecuteGCode("G00 G53 X" + toolManualPosition.X + " Y" + toolManualPosition.Y)){
                return false;
        }else if(result != DialogResult.No){
            exec.AddStatusmessage("M6: Manual tool " + action.ToString().ToLower() + " for T" + toolNumber + " was canceled");
            exec.Callbutton(buttonCancel);
            return false;
    if(!toolManualATCPrompts){
        if(action == ToolChangeAction.Unload || !toolManualToolOffsetProbePrompt || toolOffsetProbeAfterToolChange){
            result = Prompt("M6: Manual Tool Change", action + " T" + toolNumber + " and press OK to continue\n" + toolDesc, "OKCancel", PromptStatus.Warning);
        }else{
            result = Prompt("M6: Manual Tool Change", action + " T" + toolNumber + " and press Yes to measure tool offset, No to continue\nCurrent offset Z"+ FormatD(GetOffsetZ(toolNumber)) + "\n" + toolDesc, "YesNoCancel", PromptStatus.Warning);
            // force tool offset probe
            toolOffsetProbeAfterToolChange = true;
        }else if(result != DialogResult.OK && result != DialogResult.No){
            exec.AddStatusmessage("M6: Manual tool change for T" + toolNumber + " was canceled");
            return false;
    }else{
        // check if in tool release position
       // if(!AssertClampPosition(atcLEDToolClamp, false, atcLEDToolRelease,true)){  dc modified
         if(true){
            result = Prompt("M6: Manual Tool Change", (action == ToolChangeAction.Load ?
                "Press OK to open tool clamp" :
                "Secure T" + toolNumber + " and press OK to release tool") +
                "\n" + (action == ToolChangeAction.Load ? "" : toolDesc), "OKCancel",
                action == ToolChangeAction.Unload ? PromptStatus.Warning : PromptStatus.None // warning for unload - tool drop!
            if(result != DialogResult.OK){
                return false;
            ATCOpen(atcOutputToolRelease, atcOutputToolClamp, atcOutputPurge, atcPurgeOffDelayMS);
        // check if skip reclamp - manual tool change back to back
        if(!skipClamp){
            result = Prompt(
                "M6: Manual Tool Change", action + " T" + toolNumber + " and press OK to " + (action == ToolChangeAction.Load ? "clamp tool" : "continue") + "\n" + toolDesc, "OKCancel",
                action == ToolChangeAction.Unload ? PromptStatus.Warning : PromptStatus.None // warning for unload as motion will happen after
            ATCClose(atcOutputToolRelease, atcOutputToolClamp, atcOutputPurge, atcToolClampOffDelayMS);
                return false;
            if(action == ToolChangeAction.Load){
                if(!toolManualToolOffsetProbePrompt || toolOffsetProbeAfterToolChange){
                    result = Prompt("M6: Manual Tool Change", "Press OK to continue", "OKCancel", PromptStatus.Warning); // warning for motion after
                }else{
                    result = Prompt("M6: Manual Tool Change", "Press Yes to measure tool offset for T" + toolNumber + ", No to continue\nCurrent offset Z"+ FormatD(GetOffsetZ(toolNumber)) + "\n" + toolDesc, "YesNoCancel", PromptStatus.Warning);
                    return false;
    // move back to safe Z - just in case
    if(!ExecuteGCode("G00 G53 Z" + zSafe)){
        return false;
    return true;
if(toolCurrentNumber > 0){
    if(!toolCurrentStorable){
        if(!ExecuteManualToolChange("T" + toolCurrentNumber + " not storable, manual tool change required", ToolChangeAction.Unload, toolCurrentNumber, toolCurrentDesc, toolNewIsManual)){
            return;
        if(toolCurrentSlot > 0){
            toolCurrentSlot = 0;
            exec.Writekey(profileToolTableSlotSection, "Slot" + toolCurrentNumber, toolCurrentSlot.ToString());
    }else{
        // if auto-assign enabled and current tool slot is not assigned (zero)
        if(profileAutoAssignToolSlot && toolCurrentSlot < 1){
            // get current used slots
            var usedSlots = new System.Collections.Generic.List<int>();
            for(var i=1; i <= 96; i++){
                 var slot = int.Parse(exec.Readkey(profileToolTableSlotSection, "Slot" + i, "0"));
                 if(slot > 0){
                    usedSlots.Add(slot);
            // find an empty slot #
            var emptySlot = 0;
            for(var i=1; i<toolSlots.Length; i++){
                if(!usedSlots.Contains(i)){
                    emptySlot = i;
                    break;
            if(emptySlot > 0){
                exec.AddStatusmessage("M6: assigning T" + toolCurrentNumber + " to empty slot #" + emptySlot);
                // save slot to current tool
                toolCurrentSlot = emptySlot;
            }else{
                exec.AddStatusmessage("M6: no available tool slots for T" + toolCurrentNumber);
        if(toolCurrentSlot < 1){
            // release current tool manually
            if(!ExecuteManualToolChange("Tool not assigned slot, manual tool change required", ToolChangeAction.Unload, toolCurrentNumber, toolCurrentDesc, toolNewIsManual)){
                return;
        }else{
            // unload/release tool via ATC
            exec.AddStatusmessage("M6: unloading T" + toolCurrentNumber + " into slot #" + toolCurrentSlot);
            var toolSlotPosition = toolSlots[toolCurrentSlot];
            var toolSlotOffsetPosition = new Position(toolSlotPosition.X + toolChangeSlotOffset.X, toolSlotPosition.Y + toolChangeSlotOffset.Y, toolSlotPosition.C + toolChangeSlotOffset.C); //DC added C
            if(!ExecuteGCode(
                // move to safe z
                "G00 G53 Z" + zSafe,
                // move to tool slot offset position
                "G00 G53 X" + toolSlotOffsetPosition.X + " Y" + toolSlotOffsetPosition.Y + " C" + toolSlotOffsetPosition.C,   //DC added C
                // move to tool slot position (if top-unload)
                (toolSlotIsSideLoad ? "" : "G00 G53 X" + toolSlotPosition.X + " Y" + toolSlotPosition.Y),
                // move Z axis to tool release position, with offset if not side-load
                "G00 G53 Z" + (toolSlotIsSideLoad ? toolChangeReleaseZ : Math.Max(toolChangeReleaseZ + toolChangeOffsetZ, toolChangeReleaseZ)),
                // move Z axis to tool release position (if top-load)
                (toolSlotIsSideLoad ? "" : "G01 G53 F" + toolChangeFeedRate + " Z" + toolChangeReleaseZ),
                // move to tool slot position (if side-unload)
                (toolSlotIsSideLoad ? "G01 G53 F" + toolChangeFeedRate + " X" + toolSlotPosition.X + " Y" + toolSlotPosition.Y : "")
                return;
            // eject tool (3 attempts)
            var counter = 0;
            while(counter < 3 && (counter < 1 || !AssertClampPosition(atcLEDToolClamp, false, atcLEDToolRelease, true))){
                counter++;
                if(counter > 1){
                    exec.AddStatusmessage("M6: retrying to eject T" + toolCurrentNumber + ", attempt #" + counter);
                ATCOpen(atcOutputToolRelease, atcOutputToolClamp, atcOutputPurge);
            // check if tool released
            if(!AssertClampPosition(atcLEDToolClamp, false, atcLEDToolRelease, true)){
                exec.AddStatusmessage("M6: failed to eject T" + toolCurrentNumber);
                Prompt("M6: Tool Change Failed", "Failed to eject T" + toolCurrentNumber + "\n" + toolNewDesc, "OK", PromptStatus.Error);
                return;
            // move Z axis up
            if(!ExecuteGCode(
                "G01 G53 F" + toolChangeFeedRate + " Z" + Math.Min(toolChangeReleaseZ + toolChangeOffsetZ, zSafe))
                return;
            // check that nothing is spindle
            if(!AssertClampPosition(atcLEDToolClamp, false, atcLEDToolRelease, false)){
                exec.AddStatusmessage("M6: failed to eject T" + toolCurrentNumber + " or close drawbar");
                Prompt("M6: Tool Change Failed", "Failed to eject tool or close drawbar", "OK", PromptStatus.Error);
                return;
            if(!ExecuteGCode(
                // move to tool slot offset position (prevents traveling over tool slots)
            // Move C axis back to Park
            "G00 G53 C" + toolParkC //DC Added C return to park
                return;
// nothing should be in spindle at this point - allow being in release position
if(!AssertClampPosition(atcLEDToolClamp, false, atcLEDToolRelease)){
    exec.AddStatusmessage("M6: spindle not empty or drawbar ajar");
    Prompt("M6: Tool Change Failed", "Spindle not empty or drawbar ajar", "OK", PromptStatus.Error);
    return;
if(!exec.Ismacrostopped()) {
    exec.Setcurrenttool(0);
    // reset tool offset
    if(!ExecuteGCode("G49")){
        return;
}else{
    return;
// if new tool is not in a slot
if(toolNewIsManual){
    if(!ExecuteManualToolChange("T" + toolNewNumber + " not available, manual tool change required", ToolChangeAction.Load, toolNewNumber, toolNewDesc)){
        return;
}else if (toolNewNumber > 0 ){
    // load/clamp tool via ATC
    exec.AddStatusmessage("M6: loading T" + toolNewNumber + " from slot #" + toolNewSlot);
    var toolSlotPosition = toolSlots[toolNewSlot];
    if(!ExecuteGCode(
        // move to safe z
        "G00 G53 X" + toolSlotPosition.X + " Y" + toolSlotPosition.Y,
        // move Z axis to tool clamp position with offset
        "G00 G53 Z" + Math.Max(toolChangeClampZ + toolChangeOffsetZ, toolChangeClampZ)
        return;
    // open clamp
    // check that clamp opened
        exec.AddStatusmessage("M6: failed to open drawbar for T" + toolNewNumber);
        Prompt("M6: Tool Change Failed", "Failed to open drawbar for T" + toolNewNumber + "\n" + toolNewDesc, "OK", PromptStatus.Error);
        return;
    // move Z axis down to tool clamp position
    if(!ExecuteGCode(
        "G01 G53 F" + toolChangeFeedRate + " Z" + toolChangeClampZ
        // Movement was interrupted, so might not be safe to close automatically
        Prompt("M6: Tool Change Interrupted", "Manual closure of ATC is required", "OK", PromptStatus.Error);
        return;
    // close air and clamp
    // check tool is clamped
    if(!AssertClampPosition(atcLEDToolClamp, true, atcLEDToolRelease, false)){
        exec.AddStatusmessage("M6: failed to close drawbar and clamp T" + toolNewNumber);
        Prompt("M6: Tool Change Failed", "Failed to close drawbar and clamp T" + toolNewNumber + "\n" + toolNewDesc, "OK", PromptStatus.Error);
        return;
    // remove tool from slot
    if(!ExecuteGCode(
        // if side-load, move to tool slot offset position
        (toolSlotIsSideLoad ? "G01 G53 F" + toolChangeFeedRate + " X" + toolSlotOffsetPosition.X + " Y" + toolSlotOffsetPosition.Y : "" ),
        // if top-load, move to tool clamp position with offset
        (toolSlotIsSideLoad ? "" : "G00 G53 Z" + Math.Max(toolChangeClampZ + toolChangeOffsetZ, toolChangeClampZ))
        return;
    // check (again) tool is clamped
        return;
     if(!ExecuteGCode(
        return;
// check if nothing is clamped in spindle
if(toolNewNumber > 0 && !AssertClampPosition(atcLEDToolClamp, true, atcLEDToolRelease, false)){
    exec.AddStatusmessage("M6: T" + toolNewNumber + " not in spindle or drawbar ajar");
    Prompt("M6: Tool Change Failed", "T" + toolNewNumber + " not in spindle or drawbar ajar\n" + toolNewDesc, "OK", PromptStatus.Error);
    return;
    exec.Setcurrenttool(toolNewNumber);
    // apply tool offset if enabled
    if(applyToolOffset && !ExecuteGCode("G43 H" + toolNewNumber)){
        return;
    // execute tool offset probe if enabled
    if(toolNewNumber > 0 && toolOffsetProbeAfterToolChange){
        var macro = toolOffsetProbeMacro + " H" + toolNewNumber;
        exec.AddStatusmessage("M6: executing tool offset probe " + macro);
        if(!ExecuteGCode(macro)){
            return;
    if(!ExecuteGCode(
        // move to safe z
        // move back to original XY position if enabled
        (restoreXYPosition ? "G00 G53 X" + originalPosition.X + " Y" + originalPosition.Y : ""),
        // restore modal
        String.Join(" ", Array.FindAll(originalModal,
            // if applyToolOffset, filter out original G43/G49
            modal => !applyToolOffset || (!modal.StartsWith("G43") && modal != "G49")
        return;
}else{
    return;
#Events
// ### GLOBAL UTILS ###
private bool ExecuteGCode(params string[] lines) {
    if(exec.Ismacrostopped() || exec.GetLED(25)){
        return false;
    var gcode = new List<string>(lines);
    // gcode.ForEach(line =>  exec.AddStatusmessage(line));
    exec.Codelist(gcode);
    var result = !exec.Ismacrostopped() && !exec.GetLED(25); // !STOP && !RESET
    return result;
private string FormatD(double? num) {
    return num != null ? String.Format("{0:0.0###}", num.Value) : "<null>";
private DialogResult Prompt(string title, string messsage, string button, PromptStatus status = PromptStatus.None) {
    var result = exec.Informplugin("Messages.dll",
    string.Format("{0}{1}:{2}|{3}",
        status == PromptStatus.Error ? "#" : status == PromptStatus.Warning ? "!" : "",
        button, title, messsage
    return result is DialogResult ? (DialogResult)result : DialogResult.None;
private void ATCOpen(PortPin outputRelease, PortPin? outputClamp, PortPin outputAir, int airOffDelayMS = 0) {
    if(outputClamp != null){
        exec.Clroutpin(outputClamp.Value.Port, outputClamp.Value.Pin);
        Thread.Sleep(250);
    exec.Setoutpin(outputRelease.Port, outputRelease.Pin);
    Thread.Sleep(250);
    exec.Setoutpin(outputAir.Port, outputAir.Pin);
    Thread.Sleep(250);
    if(airOffDelayMS > 0){
        // turn air off after delay
        Thread.Sleep(airOffDelayMS);
        exec.Clroutpin(outputAir.Port, outputAir.Pin);
private void ATCClose(PortPin outputRelease, PortPin? outputClamp, PortPin outputAir, int clampOffDelayMS = 0) {
    Thread.Sleep(250);
    exec.Clroutpin(outputRelease.Port, outputRelease.Pin);
    Thread.Sleep(250);
        exec.Setoutpin(outputClamp.Value.Port, outputClamp.Value.Pin);
        Thread.Sleep(250);
        if(clampOffDelayMS > 0){
            // turn tool clamp off after delay
            Thread.Sleep(clampOffDelayMS);
private bool AssertClampPosition(int clampLed, bool clampExpected, int releaseLed, bool? releaseExpected = null) {
    var retry = 4;
    var debounce = 2;
    var result = true;//turn of clamp check dc
return result;
    do{
        // dwell after first
        if(debounce < 2 || retry < 4){ Thread.Sleep(250); }
        var clampState = exec.GetLED(clampLed);
        var releaseState = exec.GetLED(releaseLed);
        result = clampState == clampExpected && (releaseExpected == null || releaseState == releaseExpected.Value);
        debounce = result ? debounce - 1 : 2;
        retry = result ? retry : retry - 1;
    }while(retry > 0 && debounce > 0 && !result);
    return result;
private double GetOffsetZ(int offsetNumber) {
    var fieldStartIdxToolZ_1 = 195; // 196-215 - T1-20
    var fieldStartIdxToolZ_2 = 900; // 921-996 - T21-96
    var fieldStartIdxToolZ = offsetNumber < 21 ? fieldStartIdxToolZ_1 : fieldStartIdxToolZ_2;
    var offsetCurrentZ = offsetNumber > 0 ? double.Parse(AS3.Getfield(fieldStartIdxToolZ+offsetNumber)) : 0.0D;
    return offsetCurrentZ;
private enum PromptStatus {
    Error = -1,
    None = 0,
    Warning = 1
private enum ToolChangeAction {
    Load,
    Unload
delegate bool QTCDelegate (string status, ToolChangeAction action, int toolNumber, string toolDesc, bool skipClamp = false);
private struct Position {
    public Position(double x, double y) {
        this.X = x;
        this.Y = y;
    public double X;
    public double Y;
private struct PortPin {
    public PortPin(int port, int pin) {
        this.Port = port;
        this.Pin = pin;
    public int Port;
    public int Pin;
PostPosted: Sun Oct 29, 2023 6:49 pm
by dezsoe
Hi Delco,
You got the error messages because you left out 2 commas from line 439 and 554. After you put the commas there you'll be able to compile the macro and get real error messages. Now the problem is that the Position structure works only with 2 parameters, x and y. So, to move also the C you have to change that structure and every other code which uses it.
I did only a quick investigation, understanding the whole macro takes more time. Here are the 2 blocks corrected:
            if(!ExecuteGCode(
                "G00 G53 X" + toolSlotOffsetPosition.X + " Y" + toolSlotOffsetPosition.Y,
                return;
     if(!ExecuteGCode(
        return;
PostPosted: Mon Oct 30, 2023 12:48 am
by Delco
Thanks , once I understood the position structure only had 2 fields I was able to add a third and a default value and got it working . I also added a few extra moves etc in . Thanks , the stumbling block was that 2 fields error :)
PostPosted: Thu May 15, 2025 9:42 pm
by Mark Kraus
I would definitely be interested in paying someone to write and or polish some macros especially for tool changing on a cnc router (straight line of tools) and a future purchase of a vmc. Long time uccnc user whos son does some macros but not to in depth. We have a bridgeport series 2 running uccnc
