Make custom button and set toggle
Postby DKMaker » Fri Apr 07, 2023 7:50 pm
Hi i want to have a Custom button for a relay and i use a button with button number 20011 that works fine - but i want the green thing to light on as a toggle button - how do i emulate that?
Same as on Spindle CW / mist etc.. Can i somehow set the state for a "macro" button or what is the correct workarround to emulate this behavior.
And how do i select an item if lets say the item is under another object? I placed a label on a LED but i could not select it afterwards - so i had to move one of them to select it again, is there a hotkey to cycle between elements?
DKMaker
Re: Make custom button and set toggle
Postby dezsoe » Fri Apr 07, 2023 9:14 pm
Set toggletype to true and use double images. The left half is for the off, the right is for the on state. In your macro use AS3.Switchbutton(true/false, buttonnomber); to turn the button on/off.
At the moment you can only select the topmost control.
Postby ger21 » Sat Apr 08, 2023 1:24 am
The way we used to do this with Mach3 is to place the LED first, then place a transparent button over the LED.
But you don't need to do this in UCCNC, because you have Toggle Buttons, as explained above.
Users browsing this forum: Battwell, Bing [Bot] and 4 guests
