is there a way, the get a checkbox value (true or false or 0 or 1) and use it in an if line?
I created a checkbox with the No. 20001 and would like to use it as an indicator if I use a length sensor or if I use just cables on a PCB.
I created a field (20002) which has the value of the height of the sensor. My macro already works to check this value and use it for the new height.
But I would like to use the checkbox to indicate what shall be used, means the if line should check if the box is true = height of length sensor (32.57mm) or false than the height shall be 0
BR
Roy
