Self Made Jog Pendat Macro Help
Postby mgolec » Thu Nov 14, 2019 7:40 pm
hi everybody,
in my old Mach3 times i worked on a jog pendant, which i will use also in uccnc.
My set up: UCCNC --> UC400ETH --> Stepper BoB
My question is if i can change the Axis to X,Y,Z with one button?
Maybe you can help me with my problem.
MPG works, but only for one Axis...
I would like to have a
SET Button --> Change from Code 220 to 221 to 222
ZERO Button --> SET Active Axis Working Zero
HOME Button --> Active Axis Homing
OUTPUT 1 --> X Axis Active
OUTPUT 2 --> Y Axis Active
OUTPUT 3 --> Z Axis Active
In Mach it works with Macros, but i dont know if it works also in UCCNC.
Maybe you can help me a bit? :)
I made the Pendat with this tutorial from Gerhard Günzel. (See also the Codes at the Page).
http://www.emagu.de/Mach3-Handrad.htm
Maybe you can help me a bit,
thanks very much.
Markus
mgolec
Re: Self Made Jog Pendat Macro Help
Postby Robertspark » Sat Nov 16, 2019 1:14 pm
This should work for you....
You need 3x macro files creating .... M20001.txt, M20002.txt and M20003.txt
Place them within your profile
Then you need to
GO TO SETTINGS >> IO TRIGGER >> I.TRIGGER
Set PIN + PORT references for each of the INPUTS corresponding MACRO#below
-> input #1 - SET ACTIVE AXIS >> 20001
-> input #2 - ZERO ACTIVE AXIS >> 20002
-> input #3 - HOME ACTIVE AXIS >> 20003
THEN
GO TO SETTINGS >> IO TRIGGER >> O.TRIGGER
Set PIN + PORT references for each of the OUTPUTS corresponding below:
-> output #1 - X AXIS ACTIVE ->> LED 155
-> output #2 - X AXIS ACTIVE ->> LED 156
-> output #3 - X AXIS ACTIVE ->> LED 157
The contents of the 3 files are as follows:
M20001.txt MACRO (CHANGE MPG AXIS MACRO)
________________________________________
 UCCNC Macro for simple pendant control
3 inputs + 3 OUTPUTS
-> output #2 - Y AXIS ACTIVE
-> output #3 - Z AXIS ACTIVE
NOTE: DEFAULT AXIS IS "Z" at startup.... {not saved at reboot, if required can use construction and deconstructor macro to set and save flags....  should not be that important as it's just a button press}
Robertspark 16/NOV/2019, no copyright in any form use as you wish, just update with a version + description of the update
*SETUP*
THEN
BTN# -> 100   ZeroX   Zeros the X axis position.
BTN# -> 101   ZeroY   Zeros the Y axis position.
BTN# -> 102   ZeroZ   Zeros the Z axis position.
BTN# -> 103   ZeroA   Zeros the A axis position.
BTN# -> 104   ZeroB   Zeros the B axis position.
BTN# -> 105   ZeroC   Zeros the C axis position.
BTN# -> 106   ZeroAll   Zeros All axis position.
BTN# ->  107   HomeX   Runs the X axis to the home sensor.
BTN# -> 108   HomeY   Runs the Y axis to the home sensor.
BTN# -> 109   HomeZ   Runs the Z axis to the home sensor.
BTN# -> 110   HomeA   Runs the A axis to the home sensor.
BTN# -> 111   HomeB   Runs the B axis to the home sensor.
BTN# -> 112   HomeC   Runs the C axis to the home sensor.
BTN# -> 220   220   MPGXaxisselect   Selects the X axis for the MPG jog.
BTN# -> 221   MPGYaxisselect   Selects the Y axis for the MPG jog.
BTN# -> 222   MPGZaxisselect   Selects the Z axis for the MPG jog.
BTN# -> 223   MPGAaxisselect   Selects the A axis for the MPG jog.
BTN# -> 224   MPGBaxisselect   Selects the B axis for the MPG jog.
BTN# -> 225   MPGCaxisselect   Selects the C axis for the MPG jog.
if (AS3.GetLED(155) == true){
exec.Callbutton(221);
return;
if (AS3.GetLED(156) == true){
exec.Callbutton(222);
return;
if (AS3.GetLED(157) == true){
exec.Callbutton(220); // comment out if you have a  A, B or C axis jog machine.
//exec.Callbutton(223); // uncomment function if you have a A, B or C axis machine.
return;
// ** may need to change the below sequence if you have a XYZ+BC OR AN XYX+B OR and XYZ-C machine etc .... sure you can figure it out!
if (AS3.GetLED(158) == true){
exec.Callbutton(220); // comment out if you have a B,or C axis jog machine.
//exec.Callbutton(224); // uncomment function if you have a B or C axis machine.
return;
if (AS3.GetLED(159) == true){
exec.Callbutton(220); // comment out if you have a B or C axis jog machine.
//exec.Callbutton(224); // uncomment function if you have a B axis jog machine.
//exec.Callbutton(225); // uncomment function if you have a C axis machine.
return;
if (AS3.GetLED(160) == true){   // C axis Active
exec.Callbutton(220); // comment out if you need to....
return;
M20002.txt MACRO (ZERO ACTIVE AXIS)
*SETUP*
THEN
exec.Callbutton(100);
return;
exec.Callbutton(101);
return;
exec.Callbutton(102);
return;
exec.Callbutton(103);
return;
exec.Callbutton(104);
return;
exec.Callbutton(105);
return;
M20003.txt MACRO (HOME ACTIVE AXIS)
*SETUP*
THEN
exec.Callbutton(107);
return;
exec.Callbutton(108);
return;
exec.Callbutton(109);
return;
exec.Callbutton(110);
return;
exec.Callbutton(111);
return;
exec.Callbutton(112);
return;
M20003.txt
(2.53 KiB) Downloaded 526 times
M20002.txt
(2.53 KiB) Downloaded 504 times
M20001.txt
(3.23 KiB) Downloaded 508 times
Postby mgolec » Sat Nov 16, 2019 2:16 pm
Hi!
Thank you very much!
It works phanomenal!!! :)
I will make a tutorial for this one.
Greets and Thank you,
Markus
mgolec
