Re: rotary tool changer- carousel
Posted: Mon Jul 09, 2018 9:09 pm
theres no reverse run on the drive- has to be done via a contactor to reverse
UCCNC machine control software support forum
http://forum.cncdrive.com/
// Carousel toolchanger code
// Original Code by Terry Parker, Adapted to the AXYZ CNC by Arturo Duncan
// Some code for the original linear tool change which is not used was left there intentionally and is commented
// MessageBox.Show(" New Tool Change Macro Newtool=");
//Tool positions definition
int Chuckopenport = 1;
int Chuckopenpin = 16;
// Tool carusel driven by the B axis.
double[] ToolB = new double[11];
ToolB[0] = 0; // Tool0 B position
//Angle at which each tool is.
ToolB[1] = 36*(1-1); // Tool1 B position
ToolB[2] = 36*(2-1); // Tool2 B position
ToolB[3] = 36*(3-1); // Tool3 B position
ToolB[4] = 36*(4-1); // Tool4 B position
ToolB[5] = 36*(5-1); // Tool5 B position
ToolB[6] = 36*(6-1); // Tool6 B position
ToolB[7] = 36*(7-1); // Tool7 B position
ToolB[8] = 36*(8-1); // Tool8 B position
ToolB[9] = 36*(9-1); // Tool9 B position
ToolB[10] = 36*(10-1); // Tool10 B position
//Read and store the position of the machine before doing the tool change so we can send the spindle to where it was when the tool change was called.
double x = exec.GetXpos(); // GetOEMDRO(83)
double y = exec.GetYpos(); // GetOEMDRO(84)
double z = exec.GetZpos(); // GetOEMDRO(85)
double a = exec.GetApos(); // GetOEMDRO(86)
double b = exec.GetBpos(); // GetOEMDRO(87)
double c = exec.GetCpos(); // GetOEMDRO(88)
// MessageBox.Show("Newtool=");
// These are the machine constants. The positions in the machine coordinate system where phisical things are.
double SafeZ = -.5;
double Ztoolrelease = 88;
double Ztoolpickup = 86;
int MaxToolNum = 10; //'Max number off tools for the changer
double ToolDown = -5.339; //'Z Pos to Get or drop a tool
double ToolUp = -0; //'Z Hieght to Rapid from tool to tool
double DustCollector = 0.154;
double ToolProbePos = -3.1336;
double YTootChangePos = -7.8;
double YTootPos = -11.6913;
double SpindleSpeed = Convert.ToDouble(AS3.Getfield(870));
int Newtool = exec.Getnewtool();
int Currenttool = exec.Getcurrenttool();
if(Currenttool == 0) // If new tool number is -1 means a missing T code, so we need to stop here...
MessageBox.Show("The Current TOOL # is out of range 1 - 10 , Correct the Value and Restart");
exec.Stop();
return;
if(Newtool == -1) // If new tool number is -1 means a missing T code, so we need to stop here...
return;
if(Newtool <1 || Newtool >10) // Tool number is out of range, so we need to stop here...
return;
if(Newtool == Currenttool) // Same tool was selected, so do nothing, stop here...
return;
if(Newtool == 0 || Newtool >10) // If new tool number is 0 means a missing T code, so we need to stop here...
MessageBox.Show("The TOOL # is out of range 1 - 10 , Correct the Value and Restart");
exec.Stop();
return;
if(!exec.GetLED(56)||!exec.GetLED(57)||!exec.GetLED(58)||!exec.GetLED(60)) // If machine was not homed then it is unsafe to move in machine coordinates, stop here...
MessageBox.Show("The machine was not yet homed, do homeing before executing a tool change!");
exec.Stop();
return;
while(exec.IsMoving()){}
// Get current XY machine coordinates to return to this position at the end of the macro
double Xoriginalpos = exec.GetXmachpos();
double Yoriginalpos = exec.GetYmachpos();
// Stop spindle if running and Move Z up
exec.Stopspin();
//MessageBox.Show("G00 G53 Z+ SafeZ"); // Move Z up");
exec.Code("G00 G53 Z"+ SafeZ); // Move Z up
// Open Dust Collector
exec.Setoutpin(2,1); // Open the Dust Collector
if(Currenttool!=0) // No need to drop down tool if current tool number is zero
// Drop old tool
// exec.Code("G00 G53 "+" B" + ToolB[Currenttool]);
//while(exec.IsMoving()){}
// Drop current tool
//exec.Code("G00 G53 Z"+ Ztoolrelease); // Move Z axis down to tool holder position
//exec.Setoutpin(Chuckopenport, Chuckopenpin); // Open the chuck with pneumatic valve
//exec.Wait(1000); // Wait one 1000msec
//exec.Code("G00 G53 Z"+ SafeZ); // Move Z up
// Move to new tool position on XY plane
// MessageBox.Show("G00 G53 Y"+DustCollector+ "B "+ ToolB[Currenttool]);
exec.Code("G00 G53 Y"+DustCollector+" B" + ToolB[Currenttool]);
// MessageBox.Show("exec.Code(G00 G53 Y+YTootChangePos)");
exec.Code("G00 G53 Y"+YTootChangePos);
// MessageBox.Show("exec.Code(G00 G53 Z+ToolDown)");
exec.Code("G00 G53 Z"+ToolDown);
//Wait unti spindle is off
//Check that the spindle is really off before delivering the tool
do
exec.Wait(50);
//MessageBox.Show("SpindleSpeed ="+SpindleSpeed );
while(SpindleSpeed != 0);
// MessageBox.Show("exec.Code(G0 G53 Y+YTootPos+.25)");
exec.Code("G0 G53 Y"+(YTootPos+.1));
// MessageBox.Show("exec.Code(G1 F30 G53 Y+YTootPos)");
exec.Code("G1 F30 G53 Y"+YTootPos);
//MessageBox.Show("exec.Code(G4 P.75)");
exec.Code("G4 P.75");
// Tool Release
{exec.Setoutpin(2,14); // Release Tool
// MessageBox.Show("exec.Code(G1 F10 G53 Z & ToolDown+.25)");
exec.Code("G1 F10 G53 Z" + (ToolDown+.1));
exec.Clroutpin(2,14); // Clamp Tool
// MessageBox.Show("exec.Code(G0 G53 Z + ToolUp-2)");
exec.Code("G0 G53 Z" + (ToolUp-2.25));
// MessageBox.Show("exec.Code(G0 G53 BToolB[Newtool])");
exec.Code("G0 G53 B"+ToolB[Newtool]);
// MessageBox.Show("exec.Code(G0 G53 Z & ToolUp-2)");
// MessageBox.Show("exec.Code(G0 G53 Z & ToolDown+.25)");
exec.Code("G0 G53 Z" + (ToolDown+.1));
// MessageBox.Show("exec.Code(G0 G53 Z & ToolDown);");
exec.Code("G1 F10 G53 Z" + ToolDown);
// Clamp Tool
// MessageBox.Show("exec.Code(G1 F30 G53 Y+YTootPos-.2)");
//exec.Code("G1 F30 G53 Y"+(YTootPos+1));
//MessageBox.Show(" exec.Code(G00 G53 Z+ SafeZ)");
//MessageBox.Show(" exec.Code(G00 G53 Y+ DustCollector+5)");
// exec.Code("G00 G53 Y20"); // Bang the Dust Collector
// while(exec.IsMoving()){}
// Move back to start point
//MessageBox.Show("exec.Code(G00 G53 X + Xoriginalpos + Y + Yoriginalpos)");
exec.Code("G00 G53 X" + Xoriginalpos + " Y" + Yoriginalpos);
//MessageBox.Show("Reset Tool Offset");
exec.Code("G49"); // Reset Tool Offset
exec.Wait(200);
AS3.Setfield(Newtool,1003);
if(!exec.Ismacrostopped()) // If tool change was not interrupted with a stop only then validate new tool number
exec.Setcurrenttool(Newtool); //Set the current tool -> the new tool
//MessageBox.Show("exec.Code(G43 H+Newtool)");
exec.Code("G43 H"+Newtool); // Load new tool offset
exec.Wait(200);
//MessageBox.Show("Tool change done.");
else
exec.StopWithDeccel();
MessageBox.Show("Tool change was interrupted by user!");
Vmax549 wrote:UCCNC does not use slot Numbers only Tool numbers so I am not sure of your request. IF you look closely my example shows teh tool table where teh Slot Numbers can be assigned to a tool number for reference. Then you can auto update teh tool table based on teh slot numbers requested.
Now it would be NICE if UCCNC recognized slot#s as an ATC option but it does not.
(;-) TP
Spinweight wrote:@ThreeDJ16
Hows your ATC project working?
I have a similar type Geneva drive carousel.
I would be excited to see an example of a working macro for it.
