manual switching of a macro while a Gcode program is running
Postby CADdy » Wed Feb 14, 2018 10:40 am
Hi all,
in October 2017 you helped me with my first attempts with macros very professionally. Now I have a question about that:
Is it possible to switch the macro while a Gcode program is running?
Best Regards
Peter
CADdy
Re: manual switching of a macro while a Gcode program is run
Postby dezsoe » Wed Feb 14, 2018 11:06 am
What do you mean by switching a macro? You cannot start a macro by pressing a button while cycle is running. What do you want to do?
Postby CADdy » Wed Feb 14, 2018 1:51 pm
Hi dezsoe,
okay, thanks for your answer. That settles my question.
Best Regards
Peter
CADdy
Postby dezsoe » Wed Feb 14, 2018 2:10 pm
Hi Peter,
If you need to do something while cycle is running then you have to write it into a plugin. But, be careful, do only such things that do not conflict with the running code! (No movements, e.g.)
Postby CADdy » Wed Feb 14, 2018 9:07 pm
Hi dezsoe,
ah ok, thank you! No movements, only switching a waterpump for cooling the spindle when required. Later on I would like to have this done automatically.
Best Regards
Peter
CADdy
Postby Dan911 » Wed Feb 14, 2018 10:00 pm
CADdy wrote:Hi dezsoe,
Best Regards
Peter
What VFD do you have? Most have on board relays that will do this. When spindle goes on so does water pump, this is how I have my system wired.
If you need a pin to activate for another relay when spindle is on let me know and I'll modify the port pin plugin I have out there for you.
Postby CADdy » Tue Feb 27, 2018 9:46 am
Hi Dan,
sorry that I not answered immediately. I was lying in bed sick with flu.
I'm using UC400ETH now with two (simple chinese) VFD. So I have now a few pins free for switching some relais. It works!
Thanks a lot!
Peter
CADdy
