Machine Red-green colour Status Light Macro
Re: Machine Red-green colour Status Light Macro
Postby marben » Sat Nov 21, 2020 7:29 am
dezsoe wrote:OK, here is a macroloop for flashing the output if reset is on. Save it as M2xxxx.txt and set as autorun in config/general/macroloop. Don't forget to set OutPort and OutPin constants!
bool ResetState = exec.GetLED(25);
bool NewPinState;
if (ResetState != LastState)
  LastState = ResetState;
  Cnt = CntMax - 1;
if (ResetState)
  if (++Cnt == CntMax)
    Cnt = 0;
    NewPinState = !LastPinState;
  else
    NewPinState = LastPinState;
else
  NewPinState = false;
if (NewPinState != LastPinState)
  LastPinState = NewPinState;
  if (NewPinState)
    exec.Setoutpin(OutPort, OutPin);
  else
    exec.Clroutpin(OutPort, OutPin);
#Events
const int CntMax = 10;    // Flash speed in 50ms steps
const int OutPort = 2;    // Output port
const int OutPin = 2;     // Output pin
static int Cnt = 0;
static bool LastState = false;
static bool LastPinState = false;
HI, I've used this code in my setup, but is there any way to make the flashing equal? (same amount of time on and off?)
marben
Postby dezsoe » Mon Nov 23, 2020 6:57 am
It should be equal. A macroloop is called 20 times per second, the macroloop is set to change the output every 10 loops. There's no difference, the same code turns it on and off.
