Probing macro
Re: Probing macro
Postby Robertspark » Fri Dec 14, 2018 2:32 pm
Jan,
I am not going to explain this very well (I've typed a few things out a few times)
Basically because you are setting your Z axis at "0" home position at the top of your z axis travel and then probing and setting the work co-ordinate at ~30mm above the table your problem lies between the two.
I'm a bit busy at them moment but I'd suggest checking your offset settings from your workplane.
Re: Probing macro
Postby PillyWilly » Sat Dec 15, 2018 9:54 am
Battwell wrote:ive uploaded my m6 macro- does everything you want and can use any tool number.
it saves to profile so everything can be re called after a power off etc.
M6.txt
Thanks.
I will save this until I get a ATC, then I for sure will get back to you for further instructions :-)
Regards
Jan
PillyWilly
Re: Probing macro
Postby PillyWilly » Sat Dec 15, 2018 9:58 am
Robertspark wrote:Jan,
I understand Rob.
The ~30 is the height of my probe. Am I not to put that in there?
Would appreciate any help anyone can give me.
PillyWilly
